Offensive calls and texts
  • Jan 2, 2024 5:49 PM UTC
  • 4 replies
  • 276 views
I have been getting a series of very offensive calls and texts over the last few months - some of these seem automated/AI and others are somewhat personal. I have put unknown calls to voicemail and blocked each number, but they keep appearing under new numbers. Is there anything else that can be done?
Best answer by Sophia
For the calls, you can enable call control if you are postpaid. For texts, it’s a little more tricky - you might want to use the built in spam control on your phone.
Of course a last resort would be to change your number… and giving that out only to your friends/family.
Sophia
  • Jan 2, 2024 5:53 PM UTC
  • Organizer
  • Jan 2, 2024 5:54 PM UTC
What is call control and how do I turn on spam controls on the phone? Iphone 13
Sophia
  • Jan 2, 2024 5:57 PM UTC
Call control can be turned on in self serve. I use it and haven’t had a spam call… forever really. You can find it in Manage Plan and Add-ons, Call Control. Then enable it - done!
Text spam control on the iPhone 13 I’m not too familiar with, I have an Android phone. I’m sure others will chime in here to help you out :)
  • Organizer
  • Jan 2, 2024 6:13 PM UTC
Thanks very helpful - I have taken these actions and hopefully this will fix the issues.
