Not roaming in US
  • September 9, 2026
  • 9 replies
  • 57 views
I have a Canada/US plan, but I am in the US but have zero service. Is there something I can do to get this working as I am in the US for work for the day. Thanks
  • September 9, 2026
You can select manual network selection mode in neteork/Sim settings, and pick a network to connect to from the list that populates. And ensure data roaming is enabled. Let us know if it still doesn't work
  • September 9, 2026
I have manually tried connecting to the 4 US networks and they have all failed. And I have confirmed that my data roaming is turned
  • September 9, 2026
Which phone are you currently using? In the meantime, I have also flagged a rep to help you out.
  • September 9, 2026
In your Koodo self serve account, can you make sure Easy Roam is turned on?
  • September 9, 2026
I have the Samsumg A16.
I just browsed my Self Serve account and can't find anywhere to check if Easy Roam is turned on. Would you happen to know where to find that option?
  • September 9, 2026
Hi there ​@Craig M. Did you get a chance to try all the troubleshooting steps on our page here ? Resetting your network settings can clear connection issues.
  • September 9, 2026
I have tried all of those steps, except I have not tried removing the Sim card as I am not able to right now.
  • September 9, 2026
I would suggest you to insert your SIM card into another device when you are able to see if you are experiencing the same issue.
  • September 9, 2026
If you go to your plans and add-ons page, scroll down and you can see Travel with Easy Roam under Phone Services
