no text notification sound
  • Jun 27, 2024 1:23 PM UTC
  • 4 replies
  • 153 views
Why am I not receiving a sound notification when I receive a text msg..? All other sounds are coming in and all text sounds are enabled.. I check my phone and I have new text but the phone didn't notify me.. I get notification for email, calls, everything else, just not text and text sounds are on full blast..? Please help!!
Best answer by Oliver C
ok, so a couple of things to check.
1. do you have power saving mode turned on?
2. when you go to settings → Notifications → App Notifications, is your current messaging app of choice enabled / set to default messaging app?
 3. Try resetting the app preferences and clearing the cache. for preferences: settings → Apps → more options (three dots in the right corner) and reset app preferences. For clearing the cache, Settings → Apps → tap on messaging app → storage → clear cache
  • Jun 27, 2024 2:06 PM UTC
what device are you currently using? And is it for every phone contact or just one that you’re not getting the text notification for?
  • Jun 27, 2024 2:12 PM UTC
I just got a Samsung Galaxy S24 bought from Koodo and it's for all contacts!
  • Jun 27, 2024 2:23 PM UTC
  • Jun 27, 2024 2:58 PM UTC
Thank you so much! Clearing cache and phone data in both messaging apps fixed the problem! Was on the phone with the Koodo rep for over an hour trying different things nothing worked.. tried what u said and it fixed it immediately!
Thanks again,
Jey Dep
