No speed dial for Koodo voicemail
  • Sep 6, 2026 2:43 PM UTC
  • 13 replies
  • 136 views
After replacing my SIM card, speed dial 1 no longer works to access my Koodo voicemail.  I just get dead air.  And the voicemail access number does not appear on my phone anywhere.  How do I get Koodo to push that voicemail access number to my phone?  I have already spent a lot of time going in circles on Koodo assist, and have been told that I should select an option for a callback.  I have no list of options anywhere.  All I want is that number pushed to my phone.  How do I get that to happen?
Note that the subject list does not include this sort of thing, so I simply chose one of the listed subjects.
Best answer by RickNS
That voicemail number has been pushed to my phone, and that fixed my problem.
  • Sep 6, 2026 2:57 PM UTC
Hi
Which phone model are you using? The voicemail centre number is normally set automatically by Koodo, so a SIM swap can leave the handset without it.
You can still reach your mailbox by dialing 1 + your area code + your own number.
For the speed dial itself, I would try resetting network settings and then restarting the phone, then have someone call and let it ring out to test. If you're on an iPhone, check whether Apple Live Voicemail is turned on, it can cause problems with Koodo voicemail for some customers.
https://www.koodomobile.com/en/help/voicemail
  • Rockstar
I did forget to mention that my voicemail is active, callers can leave messages, and I can access them by directly dialing my number.  I just want that speed dial to work, and just need the number pushed to my phone.  It sounds so simple, yet seems so difficult...
  • Rockstar
  • Sep 6, 2026 2:59 PM UTC
I have tried resetting network settings, restarting the phone, and so on.  It is a Samsung Galaxy S24.  As noted, my voicemail is working just fine, and I can access it by dialing directly.  I just want that speed dial 1 to work, and just need Koodo to push the number to my phone.
  • Sep 6, 2026 3:17 PM UTC
Hi ​@RickNS
If you have already tried resetting the network settings and it is still not working, you would need to speak with a team member from the technical support team. You can schedule a call back with the virtual assist https://www.koodomobile.com/en/help
  • Rockstar
  • Sep 6, 2026 3:21 PM UTC
Yeah, been there, done that.  Did not get a callback last time (days ago), and still have not received one.  That entire “virtual assist” is a pretty poor effort.
  • Rockstar
  • Sep 6, 2026 3:23 PM UTC
It’s pretty simple.  All I need is that voicemail number pushed to my phone...
  • Sep 6, 2026 3:34 PM UTC
We hear you ​@RickNS and we would love to help. Unfortunately, we have limited access here on the community when it comes to technical related inquiries or issues.
We have just sent you a PM to confirm some more details, please check your community inbox when you get the chance.
  • Rockstar
  • Sep 6, 2026 4:21 PM UTC
  • Member
  • Sep 19, 2026 7:47 PM UTC
I have this exact same issue! How can I resolve this?
  • Sep 19, 2026 7:53 PM UTC
Hi ​@kiwikeeper
We are sorry to hear that you are encountering the issue!
What type of phone do you have?
Have you tried the troubleshooting steps provided above in this post?
  • Rockstar
  • Sep 19, 2026 7:54 PM UTC
I had to be really, really insistent that Koodo had to push the speed dial number to my phone.  I had already tried all the “fixes” mentioned above, with no success.  And each time I tried to contact a Koodo representative (mainly through Koodo assist), I was asked to repeat all those “fixes” with, you guessed it, no success.  I wasted a lot of time trying the fixes, interacting with Koodo assist, and on the phone with a representative who could not fix the underlying problem. I was promised contact with a technical representative, but never received the callback, and on and on and on.  It wasn’t until I posted here that I was finally put in touch with someone who could address the problem - the one I had been stating all along.  Hopefully, your post here will get that last result.  Good luck.
  • Member
  • Sep 19, 2026 8:05 PM UTC
Hi ​@kiwikeeper
I have a Samsung Galaxy S25 Ultra. I had just switched to Koodo in about May or so when this started happening. It didn't happen with my previous provider (same phone). I've tried everything and even went into a Koodo store, but they couldn't help me.
  • Sep 19, 2026 8:24 PM UTC
​@kiwikeeper
Thanks for the additional details.
We have just sent you a PM to confirm some more details, please check your communit inbox when you get the chance.
