Need replacement SIM card
  • Mar 12, 2025 12:16 PM UTC
  • 2 replies
  • 990 views
Hello,
my phone broke and the Sim card got broken in 2. How can I get a replacement Sim card ?
Thank you.
Best answer by Oliver C
So the quickest way is to simply pop into a koodo kiosk or Telus store and purchase a new sim. They usually cost about $10. Once you have the sim, simply follow the steps in the link below to register it to your account and then it will be good to use 🙂
Alternatively, you can order a replacement online through your self serve account however it can take from 3-5 business days for it to arrive. So I recommend just popping by a store as it will be much faster 👍
https://www.koodomobile.com/en/help/koodo-sim-support
  • Mar 12, 2025 12:27 PM UTC
  • Mar 12, 2025 12:29 PM UTC
You can buy one online or at any Koodo retailer, and then you can follow the steps in the following link to complete the sim swap online:
https://www.koodomobile.com/en/help/koodo-sim-support?srsltid=AfmBOoq_5wbwR9oJPLNj1JNvHp4bx2WBI-r8vpHCC90NpPBC7chSjw_d
