Need help with wifi calling Samsung s20 ultra
  • Mar 29, 2023 1:02 AM UTC
  • 17 replies
  • 855 views
Just bought a new S20 ultra but i cant use wifi calling,i can activate it and then i can give the 6 digit code that koodo sent me but after that it just cycle with the ‘’requesting service. Please wait...’’.
Had no problem with my s9 before for that feature.
Please flag a rep to unlock this feature, thank you!
Best answer by Boa_Guy Koodo
Hi there @Ginobrito  We have looked into your account, and everything looks ok, we have refreshed the backend just to be sure, please restart your device and check if everything is working for you.
  • Mar 29, 2023 1:57 AM UTC
Have you tried restarting your phone?
Are you activating Wi-Fi Calling while in an area with cellular coverage?
Have you tried resetting your phones’ network settings?
Try these troubleshooting steps and let us know if the problem persists.
  • Coach
  • Mar 29, 2023 2:09 AM UTC
I i did reset  my network settings, now when i enter the 6 digit that koodo sent me i got the ‘’ web page not availaible net :: Err_http_response_code_failure
  • Mar 29, 2023 2:33 AM UTC
Do you see the VoLTE add-on in Self Serve?
VoLTE should be added automatically, but just to make sure, check that it has been added to your Self Serve account. Login to Self Serve, click the Self Serve tab and select Mobile services > My add-ons and look for the VoLTE access add-on. VoLTE is needed in order for Wi-Fi Calling to work.
  • Coach
  • Mar 29, 2023 2:39 AM UTC
Yes I have the volte access add on for 0$
  • Mar 29, 2023 2:45 AM UTC
It’s likely you will have to go through the process of getting a new six-digit code. The previous code has probably expired. If the issue continues, we can flag a rep to take a closer look.
Are you using the same email address for Self Serve as here in the community? This allows the rep to access your account and send private messages when necessary.
  • Coach
  • Mar 29, 2023 2:52 AM UTC
I will try again but I did respect the 10 minutes timeout, and yeah it's the same email address
  • Coach
  • Mar 29, 2023 2:55 AM UTC
Yeah still the same ''requesting service. Please wait...’’.
  • Mar 29, 2023 3:00 AM UTC
Must be a glitch of some sort. I have flagged a rep to look into this. Due to the time of day, you should get a response at some point tomorrow.
  • Coach
  • Mar 29, 2023 3:05 AM UTC
Okay thank you!
  • Coach
  • Mar 30, 2023 12:38 PM UTC
Can i get some advice or help?
  • Mar 30, 2023 12:52 PM UTC
Looks like the rep may have missed the flag.
Are you a postpaid or prepaid customer?
There are two Koodo Assist platforms, one for postpaid customers, the other for prepaid customers. If still no response from the rep, I would suggest scheduling a callback through Koodo Assist and ask to speak to a tech to get this issue resolved.
Koodo Assist postpaid or Koodo Assist prepaid
  • Coach
  • Mar 30, 2023 12:53 PM UTC
I'm post paid
  • Coach
  • Mar 30, 2023 12:56 PM UTC
There is no option to get in contact with someone, only the bot with basic info about my billing
  • Mar 30, 2023 1:02 PM UTC
Follow the required prompts that you’re a Koodo customer/phone number and enter “schedule callback” (without quotation marks) into the chat window. Ignore the next set of prompts/suggestions and enter schedule callback again. At that point, you should see the prompt, Speak to a rep.
Boa_Guy Koodo
  • Koodo Alumni
  • Mar 30, 2023 1:06 PM UTC
  • Coach
  • Mar 30, 2023 6:54 PM UTC
Its working now! thanks alot sir!
  • Mar 30, 2023 10:00 PM UTC
Glad to hear Wi-Fi Calling is working!
