My phone won't stop sending the same amber alert
  • Jan 3, 2024 3:11 AM UTC
  • 3 replies
  • 999 views
I have recieved the same amber alert for the whole day even if I acknowledged in multiple times. Anyone else having this problem?
  • Jan 3, 2024 3:26 AM UTC
Have you tried this step? https://www.androidpolice.com/turn-off-amber-alerts/
  • Jan 3, 2024 5:40 PM UTC
Hi
Yes, I had disabled all settings for alert and cleaned my alert history but it was still happening. I had also rebooted my phone just in case and removed/reinserted the sim card.
In the end, I left my phone turned off for the night and for now, it seems to be okay.
Dunno what happened, I just hope it’s not something that will be a recurring problem.
  • Jan 3, 2024 6:50 PM UTC
Hi
For Canadian amber/Emergency alerts, you can’t turn it off.
Which phone was it? If you received multiple alert of the same content, there might be issue with the network settings. I would recommend you try to reset network settings of the phone to see if that can help.
