Modem router LAN light is flashing amber
  • June 14, 2026
  • 4 replies
  • 93 views
I have just switched from Altima to Telus. On the Telus modem, LAN light is blinking amber other lights are green. I have internet.
Should I be concern? What could blinking amber light on LAN means?
Sophia
  • June 14, 2026
Is there anything that seems to be missing?
  • June 14, 2026
When I looked into this issue, I read that a flashing amber LAN light might mean the connection through the LAN port is limited to 100 Mbps. Are you using a high-speed RJ45 cable by any chance?
  • June 14, 2026
No. Just regular RJ45 cable that comes with the modem.  My old Altima modem was all green light and my subscription with Altima was for 100MB.
I did more digging, some gigabit network switch is capable of 1000MB++ speed but my subscription with Telus is only 500MB.
So if the Telus modem is connected to incoming 100MB speed (from outside the house) and blink amber, it means I am only getting 100MB? Or Telus modem can boost incoming 100MB  to 500MB?
If not, I am still getting 100MB speed instead of 500MB, and over paying for what I am not getting?
  • June 14, 2026
Eh, that blinking light doesn't always mean your internet is limited to 100mbs. Most of the time, the issues are from cable or/and user hardware configuration.
Do you have another LAN cable that is Cat 5e or 6 to test with the modem? As well, have you checked your pc/laptop to make sure their port is not limited to 100mbs?
Can you run a speedtest using WiFi?
