Mobile number transfer Koodo to Public
  • July 8, 2026
  • 54 views
I have tried multiple times to switch my number from Koodo to Public mobile. I receive the message from Koodo saying that a request has been made to transfer my number, to which I reply ‘YES’ within the allocated 90 minute timeframe. After that nothing happens.
  • July 9, 2026
Are you using the Fast switch option to move from Public to Koodo?
https://www.publicmobile.ca/en/get-help/articles/switching-from-public-postpaid
Or did you sign up with Koodo independently? And now you want to port your number over?
  • July 9, 2026
I signed up with Koodo independently, and now want to transfer my number over. I have a Public SIM and my Koodo SIM card  is still n my phone and active. I just can't make the switch.
  • July 9, 2026
When you check your port status in you Koodo self serve, does it say the port is complete?
  • July 9, 2026
Since you are moving away from Koodo, the best support actually is public Mobile forum.
As well, sometimes number transfer takes few hour to finish. I would recommend you wait if the request is recent.
  • July 9, 2026
Do you know if you have Port Fraud Protection enabled on your account? That may have prevented you from porting over to Public Mobile. https://www.koodomobile.com/en/help/port-fraud-protection
I would suggest you to schedule a callback through Koodo Assist to speak with a rep and see if they can assist you with removing the block. https://Koo.do/Chat
