MMS not working at all
  • Jun 28, 2023 4:04 AM UTC
  • 7 replies
  • 1197 views
Hi! MMS is not working, not sending not recieving.  Tried to reset network setting, telus specialist personally tried to solve it also for about 40 minutes, tried also different SMS apps to send. Nothing helps.  He said it is something wrong on Koodo side.
Best answer by Dinh
Can you check your APN to see if it was set correctly as per Koodo instructions https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone
Allan M
  • Jun 28, 2023 4:34 AM UTC
What kind of phone are you using? Did MMS ever work? Do you have your cellular data turned on?
  • Organizer
  • Jun 28, 2023 5:09 AM UTC
Poco X3 Pro
Android 11.
MMS worked on Telus. See first screenshot please.
When I switched to Koodo - not working anymore - second screenshot.
Data turned on , otherwise it's asking to turn on data
  • Jun 28, 2023 6:25 AM UTC
  • Organizer
  • Jun 28, 2023 12:51 PM UTC
Sure, I did it by manual. It helped, thank you!
  • Member
  • Jul 26, 2023 9:07 PM UTC
Did you solve your problem with MMS. I also have a Poco phone and I finally got it to work.
  • Member
  • Jul 26, 2023 9:16 PM UTC
For anyone having problems with a Poco phone and MMS, these settings work for me.
APN: sp.koodo.com
Proxy:
Port:
MMSC: http://aliasredirect.net/proxy/mmsc
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
APN Protocol: ipv4
APN Roaming Protocol: ipv4
Bearer:
MVNO Type: GID
MVNO value: 4B
  • Organizer
  • Jul 26, 2023 10:23 PM UTC
APN: sp.koodo.com
Proxy:
Port:
MMS Port: 8799
MCC: 302
MNC: 220
APN Protocol: ipv4
Bearer:
MVNO Type: GID
MVNO value: 4B
Oh I just had to reset network parameters
