MMS no longer working, how I fixed it on my phone
  • Feb 17, 2024 2:02 AM UTC
  • 11 replies
  • 9558 views
Apparently after Feb 7 Koodo changed some things that wouldn’t allow me to send MMS messages. I followed the steps listed below and it still didn’t work. No suggestions on the koodo forum worked either.
https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone
As if a stroke of luck I figured it out for my phone (CAT S42) which is an android. If you haven’t been able to fix on your phone using these this is what I did.
Reset network settings.
Then follow steps on the link above… BUT instead of creating a new APN just go into the default one and change everything so it has the matching info from the link above.
  • Member
  • Feb 18, 2024 11:15 PM UTC
My wife went through 3 Koodo staff trying to fix her MMS. Hope they pick up on this post because this is what it took. Appreciate you posting 😌
  • Member
  • Feb 20, 2024 4:53 AM UTC
Thank you!!! This worked for me too. Definitely change the original Koodo APN, don’t make a new one (I tried that first and it din’t work)
  • Feb 24, 2024 8:10 AM UTC
Worked for me as well, I tried a lot of different things before this. Thank you!
  • Organizer
  • Mar 2, 2024 10:30 PM UTC
I am unable to edit the original default APN, all greyed out. Making a new APN did not work. Resetting network, turning off phone, turning off WiFi, restarting. nothing works.
Any other suggestions? Stopping being able to send MMS Wed 28 Feb 2024.
  • Mar 2, 2024 10:38 PM UTC
Hi @Mackinlo
If you have one of the models listed in the article here https://www.koodomobile.com/en/help/picturemessagingchanges, a device upgrade would be needed
  • Organizer
  • Mar 3, 2024 2:41 PM UTC
Wonderful. Can’t afford a new phone. Thanks.
  • Mar 3, 2024 8:14 PM UTC
Feel free to check out current deals here https://www.koodomobile.com/en/phones, we have some great offers for phones, some of them starting from $0 down and $0 monthy tab on 24 months (available on specific tab and plans)
If you are interested in any of the available deals, ordering online will save you the $60 connection fee. If you have questions or wish to review other deals, feel free to schedule a call back through our virtual assist and a rep will be happy to go over the available options based on your needs.
  • Organizer
  • Mar 4, 2024 12:20 AM UTC
The weird thing is that I can send photos to Samsung phones, just not iPhone phones.
Why would that be?
  • Mar 4, 2024 2:12 AM UTC
Why would that be?
Which device are you currently using? Did you recently switch from iPhone to Android?
  • Organizer
  • Mar 5, 2024 12:34 AM UTC
No. I have an older android.
  • Organizer
  • Mar 8, 2024 12:20 AM UTC
Resolved only by installing a different text messaging app (Google Messages was installed as default and had no APN settings).
