Messaging and photos
  • Mar 11, 2025 9:11 PM UTC
  • 9 replies
  • 265 views
We have converted two phones to Koodo, one Samsung and a OnePlus. After going live, the OnePlus messaging app will not send photos from the gallery and will not download photos sent to the app by others. Have looked at all data settings and see nothing that looks like a change would help. The Samsung phone continues to operate as both did before. Note: the messaging app not working does not have the small paper clip and camera icons beside the text input field, the way other messaging apps and What’s App does, so one goes out to the camera or gallery and clicks share, and the photo appears in the app but when clicking Send, it instantly fails. With the received photos, when one clicks on it to download it, it spins for a while and fails.
Best answer by Dennis
Make sure your APN settings for the OnePlus matches
https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone
Also I assume everything else for the OnePlus works (talk, regular sms, cellular data)?
  • Mar 11, 2025 9:13 PM UTC
  • Mar 11, 2025 9:48 PM UTC
Thx for the prompt reply Dennis. I recall now APN problem for other phones in the past. Under APN, when finally found, I see most of the details as in your link page above, except there is a Proxy field, which is empty, and then an MMS Proxy field, which on the phone in question has entered 74.49.0.18 address, whereas the table from your link just has mmscproxy.mobility.ca. I assume the specific address is more correct. There are other fields in the phone that do not have corresponding fields in the table, such as Server, Authentication Type, Username and Password. The stuff in the table is correctly entered from what I can see however. When I restart that phone however, the photo problem still exists. We bought this American made phone at a phone service store, and it handled photos fine when on the Rogers network, so something occurred in APN I guess when we switched over, but I can’t seem to find what needs changing.
  • Mar 11, 2025 11:15 PM UTC
You would have to follow every field APN correctly as per Koodo page. Another way to check is to use your Samsung phone as an APN settings reference.
Anyway, If that doesn’t help, your phone (One plus) might not be compatible with new Koodo MMS server as stated here  https://www.koodomobile.com/en/help/picturemessagingchanges?  If that is the case, you might not be able to use MMS on it.
  • Mar 11, 2025 11:23 PM UTC
I think the latter problem may be the issue. When the sales rep was asking his guy on the phone what to use for OnePlus phone, they told him to just put in the name of some other phone, cuz this phone wasn’t in the list of phones. I noticed when in the support pages earlier they had an icon for OnePlus phones but it defaulted to a single phone by Nokia or something. Likely the phone isn’t compatible but I will try mapping using my Samsung, and worst case, we will use whatsapp for photo tramsfers for now and upgrade the phone on a sale, cuz the package for two phones and internet was worthwhile changing over. Thanks again Dinh
  • Mar 11, 2025 11:37 PM UTC
I refuse to believe it doesnt work since there are people who are able to get it to work with some tinkering.
Please read this thread and at the end of the thread there is a link for someone that got their OnePlus 12 to work
  • Mar 12, 2025 12:29 AM UTC
Thanks again Dennis. This model is 8. Not sure if the 12 was better suited. I will get back to your last suggestion later tomorrow and will advise. DJ
  • Mar 12, 2025 1:10 AM UTC
I wouldn't suggest you try. Telus internationally closed the old mms server. On this forum, Few tried the old server for few days and it didn't work again.
Using unknown server from 3rd party source can also be risky. Make sure you know what you are getting into.
  • Mar 12, 2025 4:29 PM UTC
This is the difference I see.
MMSC
http://aliasredirect.net/proxy/koodo/mmsc    →  http://aliasredirect.net/proxy/mmsc
  • Mar 12, 2025 6:44 PM UTC
Thanks to both of you, Dennis and Dinh. I persevered as requested and it’s now working. Here is what I found. The table from Dennis’ link re Koodo fields shows two fields being MMS Proxy and MMS Port. Those exist on the OnePlus phone in Settings/Sim card/ i for info, where the fields show, but there we have two additional fields being Proxy and Port, both without ‘MMS’ in front of them. The Port number from the table was 8799 which was in the Port field only, not in the MMS Port field, rather a two digit number was there. Also, as mentioned above a specific IP address was in the MMS Proxy field while the table suggested just using mmscproxy.mobility.ca. I replaced the IP address with the latter in MMS Proxy, and I put the 8799 number into the MMS Port field. Voila!! Pictures downloaded and also were sent. Again, thanks for sticking with the issue, and for the advice. DJ
