Limiting data on prepaid
  • Jun 18, 2025 4:13 PM UTC
  • 1 reply
  • 192 views
Looking to set up a talk and text only package. The pre-paid yearly option I’m looking at also includes 30GB data. Is there a way to turn data off so taht we don’t go over and get charged?  (other than turning off cellular data on the phone)?
Best answer by Allan M
With prepaid, you are unable to go over the data since you pre pay for it. Once you’ve used it all up, you have to specifically and intentionally top up your account and buy more.
1 reply
Allan M
  • Jun 18, 2025 4:31 PM UTC
