koodo phone as hotspot
  • May 13, 2022 1:47 AM UTC
  • 2 replies
  • 257 views
hi  my firestick won’t let me use my koodo phone as hotspot.  says password wrong . is it different than one i use to log into Koodo self serve ?   Thanks for any help .   Rod
Best answer by Allan M
Yes it would be. The password for your hotspot would be in the hotspot settings of your phone. You can change it to whatever you like.
Allan M
  • May 13, 2022 1:54 AM UTC
  • May 13, 2022 1:59 AM UTC
got it !  thanks !
Rod
