Koodo eSIM compatibility for Samsung A55 5G
  • Apr 14, 2024 5:02 AM UTC
  • 1 reply
  • 733 views
Is the Koodo eSIM compatible with the new Samsung A55 5G mobile phone?
The General specification and the Samsung Expert Personnel mentioned that the model is eSIM compatible however the carrier provider should also be consulted on the compatibility.
Does anyone use Samsung A55 5G mobile that is compatible with Koodo eSIM?
Best answer by Dinh
Is the model a Canadian model? If so, it is definitely 100% compatible.
1 reply
  • Apr 14, 2024 1:14 PM UTC
