Is my phone compatible with the Koodo network?
  • Sep 5, 2021 6:46 PM UTC
  • 4 replies
  • 614 views
How can I use my IMEI number to confirm that my phone is compatible with the Koodo Network?
Sep 5, 2021 6:55 PM UTC
The IMEI tool was outdated, I don’t think Koodo would bring it back.
In the mean time, you can try this tool https://willmyphonework.net/
or their official page https://www.koodomobile.com/en/help/my-phone-compatible-koodo
  • Sep 5, 2021 6:55 PM UTC
BobTheElectrician
The old tool could tell you if your rig was compatible on at least a limited basis. With newer features, such as 5G, wifi calling and VOLTE, you may need a phone specifically certified by Koodo.
Many older US Android handsets designed for AT&T or T-Mobile networks in the USA work fine for basic data, messaging and voice, but aren’t supported by Koodo for those newer features due to firmware issues.
  • Member
  • Sep 5, 2022 4:59 AM UTC
Is your network compatible with this?
Network
5G
NR:N1/2/3/5/7/8/20/25/28/38/40/41/66/77/78/79
4G
LTE-FDD: B1/2/3/4/5/7/8/12/13/17/18/19/20/25/26/28/66
LTE-TDD: B34/38/39/40/41
3G
WCDMA: B1/2/4/5/6/8/19
CDMA EVDO: BC0/BC1
2G
GSM: B2 /B3 /B5 /B8
  • Sep 5, 2022 5:31 AM UTC
Network
5G
4G
3G
CDMA EVDO: BC0/BC1
2G
GSM: B2 /B3 /B5 /B8
The bands are ok. However, you might not be able to use volte and vowifi if the phone wasn't on the Koodo list.
