Is my data being throttled
  • Sep 9, 2023 4:06 PM UTC
  • 668 views
khrox
A few days ago my data ceased to be usable. I have over 10gb of data usage left on my account this month. I did a speed test and am receiving 2mbps. I have not changed my phone, my plan or my location. My phone is 2 years old, everything else still works just fine. I have restarted it and taken out and put back in the sim card.
  • Sep 9, 2023 4:28 PM UTC
Which phone model is it? and how about other location, did the phone show the same issue?
khrox
  • Sep 9, 2023 4:38 PM UTC
Samsung Galaxy A32. What other location? I have not changed my location.
  • Sep 9, 2023 4:50 PM UTC
Well, I meant did you bring your phone to another location like mall, car park, etc. Did the issue follow?
khrox
  • Sep 9, 2023 4:56 PM UTC
The issue persists everywhere I have been, but I haven’t gone farther than 5km away from home in the past few days.
  • Sep 9, 2023 6:39 PM UTC
If it happened every where you go, the issue could be from settings in the phone. I recommend you try to reset network settings to see if that can help.
If you have another phone available, I recommend you switch SIM card to see if there was any difference.
khrox
  • Sep 9, 2023 6:44 PM UTC
I think that may have solved the issue. Thank you so much for your help, I really appreciate it.
