international roaming not working
  • Apr 23, 2022 10:36 PM UTC
  • 8 replies
  • 545 views
I added international roaming to my phone and had it working for a little bit, but now I can’t seem to get it connected to any network. I tried resetting the network settings, switching between airplane mode and other options that’s been suggested.
Best answer by Dinh
Where are you traveling to? Could you go into the settings and try to manually search for local carrier and join?
  • Apr 23, 2022 10:45 PM UTC
  • Organizer
  • Apr 24, 2022 6:47 AM UTC
Didn’t work either and Portugal
  • Organizer
  • Apr 24, 2022 6:48 AM UTC
Didn’t work either
  • May 6, 2022 7:03 AM UTC
I am in Egypt and tried yesterday and today to add my account Roaming because i buy a new phone and when I want to use whatsapp is asking verification code send to my number
  • May 6, 2022 7:11 AM UTC
doesn’t work either
Boa_Guy Koodo
@Mohamed7  Hi there, if you were trying to add Easy Roam to your account and it didn’t work, its due to the fact that you are currently on Seasonal hold. You will need to remove seasonal holld, add the plan that you want and add the Easy Roam options.
  • May 6, 2022 6:46 PM UTC
how could I get a verification code for whatapp account
  • May 6, 2022 10:41 PM UTC
I removed the seasonal hold, and added a plan plus roaming, and still can’t receive the verification message code
