i need helpn
  • Jun 21, 2022 12:44 AM UTC
  • 8 replies
  • 185 views
Maliq Snow
I bought a prepaid 60$ plan at a Koodo booth Then lost my sim I bought a new one the next day but I haven’t made a self serve account yet how do I make one if I can’t access the account phone number and
Best answer by Sophia
Did you activate your plan with the old sim?
Sophia
  • Jun 21, 2022 1:16 AM UTC
Maliq Snow
  • Organizer
  • Jun 21, 2022 1:19 AM UTC
Yeah I did..
Maliq Snow
  • Organizer
  • Jun 21, 2022 1:22 AM UTC
Is their nothing I can do did I just waste 60$
Sophia
  • Jun 21, 2022 1:35 AM UTC
No, nothing is wasted, don’t worry :) You can create a self serve account here: https://prepaidselfserve.koodomobile.com/ - if you are not registered yet, you can use the link on the right hand side.
Then, after you have your self serve account, you can activate your new SIM with your existing number/account.
Maliq Snow
  • Organizer
  • Jun 21, 2022 1:40 AM UTC
It says I need to verify my phone number I put my number in but I can’t receive the 4 digit code since I don’t have access to the other sim with the number on it
Maliq Snow
  • Organizer
  • Jun 21, 2022 1:42 AM UTC
I know my phone number I just can’t receive texts I lost that sim that I activated the number on :/
Sophia
  • Jun 21, 2022 1:56 AM UTC
I see... In that case you should probably contact Koodo directly through Facebook or Twitter DM. Or, if you have a number they can call you back on, you can schedule a callback with the digital assistant.
Maliq Snow
  • Organizer
  • Jun 21, 2022 1:58 AM UTC
I see... In that case you should probably context Koodo directly through Facebook or Twitter DM. Or, if you have a number they can call you back on, you can schedule a callback with the digital assistant.
Okay thank you I’ll do that now I’ll leave a message through Facebook
