I have an Huawei P30 lite and I am stuck with my phone be restricted to FDN (Fixed Dial Number)
  • Dec 3, 2021 10:25 PM UTC
  • 1 reply
  • 338 views
I have an Huawei P30 lite and I am stuck with my phone be restricted to FDN. I called support and they have no clue what i am talking about. Has anyone had this issue before and is there a way to fix it, I have the unlock code and it asks me for a new unlock code and i put one in and it says that’s its invalid. Again Tech support cannot help me. They said i need a new SIM card? Can anyone advise me on this?
Best answer by rikkster
I’ve had the Huawei P30 Lite in the past and have never come across this issue. The default SIM PIN should be 1234. If a SIM PIN is entered incorrectly 3 times, your SIM will be locked and you will require a Personal Unlocking Key Code (PUK code) to reset the SIM PIN.
1 reply
  • Dec 3, 2021 10:52 PM UTC
