How to set up Number input for incoming calls
  • Oct 13, 2022 6:03 PM UTC
  • 2 replies
  • 167 views
I would like the service where callers have to input a number to get through, so robocalling is eliminated. I had it then disabled it. wondering how I can restore it.
Best answer by Allan M
You’ll want to login to your self serve account, go to your add-ons and then add one called “call control”.
Allan M
  • Oct 13, 2022 6:36 PM UTC
  • Oct 16, 2022 1:03 PM UTC
Thank you, I’ll try that!
