How do i correct my phone number in settings?
  • April 28, 2026
  • 32 views
I moved my number from another provider. It works. But in my iPhone settings, my number is still listed as the one Koodo gave me when signing up. I have tried editing the number but it doesn’t save.
Best answer by Dennis
Sorry I misread “from another provider” as “to another provider”.
If the ported number is working, then dont worry about the temp number still being visible.  It is a previously reported glitch and it appears to only be a visual glitch.
If it is not impacting your usage, I would ignore the incorrect number showing and it should self resolve over time.
  • April 28, 2026
Is this an esim?
Is there an error when you try to delete the esim profile?
  • April 28, 2026
How long has it been since you have ported the number over? When you call and text others, does the correct number show up or the temporary Koodo number?
  • Advisor
  • April 28, 2026
Yes it is an esim but no I have not tried to delete it, as I want the phone to work. I just want to edit the number displayed in cellular/settings.
yes, people calling my old number reach me.
  • April 28, 2026
  • Advisor
  • April 28, 2026
Ok thank you
