Having problems receiving images via MMS from iPhones
  • Jul 23, 2024 10:01 PM UTC
  • 10 replies
  • 614 views
Hello,
Description:
In the past 2 weeks, my phone no longer is able to receive images via MMS from iPhone users.  I get the “One or more media attachments were removed” message.
Specifics:
  • I’m using a TCL Android phone and the default Google Messages
  • It used to work fine a couple weeks ago and there was no problems to receive images via MMS from iPhone users
  • Now when I click on the attachment to download and open it displays “One or more media attachments were removed”
  • I’ve tried rebooting, taking out the SIM card, re-adding SIM card
  • Resetting the APN
Any ideas on how I can once again receive images via MMS from iPhone users?
Thx!
  • Jul 24, 2024 12:53 AM UTC
Can you check the APN settings to see if it is correct? https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone
  • Jul 24, 2024 2:53 AM UTC
The TCL was likely not supported by Koodo MMS server. More information can be found here https://www.koodomobile.com/en/help/picturemessagingchanges
Anyway, was your phone from Koodo originally?
  • Jul 24, 2024 2:14 PM UTC
I did do this back earlier this year (Feb) when Koodo mentioned the APN update.  It worked fine all year, that is until the last couple of weeks.  I checked and the APN settings match what is mentioned in the link.  That’s why i’m flumoxed as to why images sent from an iPhone aren’t coming across on my Android phone.
Any other ideas?
  • Jul 24, 2024 2:18 PM UTC
Hi Dinh, the phone was not originally from Koodo.   It’s a TCL 20 SE.  It has worked fine on the network up to now.
  • Jul 24, 2024 2:28 PM UTC
Is it just the receiving part you are hacing issues with? Did you recently update the firmware on your phone?
  • Jul 24, 2024 2:33 PM UTC
Yes, when I click on the incoming image to download it … it returns with the message “One or more media attachments were removed”.  I can send both text and images correctly to other folks using iPhone from my Android, and I can receive regular text-based texts from iPhones but not images (prior to about 2 weeks ago I could receive the images correctly from iPhones).
  • Jul 24, 2024 2:35 PM UTC
There’s been alot of updates on the phone from Google Playstore.  I don’t believe there were any firmware updates.
  • Jul 24, 2024 3:01 PM UTC
Try and clos RCS by goign to Message settings (assuming Google Messages) then General, then RCS Chat then turn off RCS.  Whether that will address the problem I have no idea but it should be easy to try.
Also, do you still have useable data on your plan?
  • Jul 24, 2024 4:22 PM UTC
Hi Robert, i tried disabling RCS, and then had a friend text me an image from his iPhone, it came back with same message “One or more media attachments were removed”.  Yes I still have a sizeable amount of data remaining on the plan this month.  Any other thoughts to try?
  • Jul 25, 2024 4:15 AM UTC
The changes has become in effect recently. It wasn’t uncommon to see report of non-canadian model phones had issue with MMS.
