Ghost voicemail notifications on Samsung S25 edge
  • Oct 25, 2026 1:49 AM UTC
  • 18 replies
  • 156 views
JasperOscarRocky
How to turn it off , i keep on getting ghost notifications after newest Samsung update to UI 9.0 , tried everything. Also for some reason notification for that section are grayed out unlike my Moto edge 24 . Also after airplane mode it comes back , so network is pushing it through  .
Whats the fix!
Best answer by JasperOscarRocky
Found the solution.
Who says AI can't be helpful.
I used this app and it blocks it , even when I try airplane mode it don't comeback.
One odd solution that actually works.
  • Oct 25, 2026 2:08 AM UTC
Since it comes back as soon as you turn airplane mode off, that sounds like the message waiting indicator being pushed from the voicemail server rather than anything in One UI. Can you call your voicemail from the handset and go through the mailbox, including the saved messages, and clear everything out? A stuck unheard message will keep re-triggering that notification.
As well, log in to Self Serve, go to Mobile Services and Manage add-ons, and check whether you have Instant Voicemail. That's the feature that pushes voicemails to the phone, so the notification may be coming from there rather than from the dialer app.
Once the mailbox is empty I would reset the network settings and restart. Koodo's voicemail page is here https://www.koodomobile.com/en/help/voicemail
JasperOscarRocky
Did everything you have mentioned and still comes back.
Looks like I'm going to have to call and ask for network reset.
Thanks for the help.
  • Oct 25, 2026 11:23 PM UTC
Let me flag a rep in the community as well.
  • Oct 26, 2026 3:46 PM UTC
Hi ​@JasperOscarRocky
Can you please confirm the last two digits of the phone number in question so we can take a closer look?
JasperOscarRocky
93 are the last two digits
Thanks
  • Oct 26, 2026 11:18 PM UTC
Have you tried calling and leaving yourself a voicemail and then accessing your voicemail again to delete it?
Also make sure cellular data is enabled when you do this.
Not sure if you have the same issue, but this was a trick to remove an unwanted voicemail notification in the past when there was no actual voicemail there
JasperOscarRocky
Yes I have , it's like it's stuck in a loop .
  • Oct 27, 2026 11:25 AM UTC
I still use a newer samsung device as my main driver and this is something that has come and gone for me, regardless of OS version. I actually never found out what a permanent fix was for those affected.
JasperOscarRocky
Update, talked to Koodo rep and I asked to have my voicemail removed. I never use it , no one calls me lol they can text or email if it's important. So far not getting any notifications but will see. Coz when wife called it still shows as active but haven't got a notification. Also if I do airplane mode it will pop up and that is odd.
If anything changes I'll update again.
JasperOscarRocky
Another update...short lived. The ghost voicemail notifications are back , so no idea if voicemail is off completely or something wrong with network.
Getting annoying 😔
JasperOscarRocky
Last and final update.
Koodo called, they had to turn off the voicemail manually.
Now it just rings and hangs up .
All good now.
JasperOscarRocky
Ok now this makes no sense.
Voicemail is off , not setup . Rings and hangs up.
Yet I'm still getting ghost voicemail notification.
Hellllllllp hahahaha
Maybe new sim ? I have an extra new one not activated.
I'm completely stumped 🤔
JasperOscarRocky
Thanks
Please read my last few updates.
I'm completely stumped it's still coming through.
  • Oct 28, 2026 3:52 AM UTC
What happens when you try your sim in another other phone (friend or family member)?
JasperOscarRocky
I have two phones, does it in both. Samsung Galaxy s25 edge and my Motorola edge 2024 .
It's very odd 😕
Benefit of Moto I can shut it off in settings, on Samsung it's grayed out for some reason and it's my main phone.
JasperOscarRocky
Found the solution.
  • Oct 28, 2026 5:17 PM UTC
If someone leaves a legit voicemail does the notification remain blocked?
JasperOscarRocky
I would think so , yes.
