eSim with Huawei.
  • May 8, 2022 2:54 PM UTC
  • 4 replies
  • 434 views
Can I use my Huawei P30 pro with Koodo? Watch about the Sim card that is integrated in the phone.
Can I use my Huawei phone with Koodo and have a eSim?
Best answer by Sophia
The phone should work just fine with Koodo, but I'm not sure if you can activate eSim. You can check this page for the phones that are currently supported: https://www.koodomobile.com/en/help/esim-and-esim-vouchers
Sophia
  • May 8, 2022 3:00 PM UTC
Allan M
  • May 8, 2022 3:27 PM UTC
Does your phone show a spot in the settings to add an esim to it?
  • May 8, 2022 9:25 PM UTC
My understanding is that the Huawei P30 Pro does not support eSIM technology. Some variants in other countries offer hybrid dual-SIM card support. The P40 and P40 Pro are the first cell phones from Huawei that offer eSIM technology.
P30 Pro Specs - scroll down to heading Network
P40 Pro Specs - scroll down to heading Network
  • May 11, 2022 1:34 AM UTC
Thanks for help!
