Can’t seem to find a definitive answer anywhere and with the holiday season soon around the corner, I’m eyeing the nothing phone to switch out my Apple 13.
Does Koodo support Nothing Phone 3a Pro and 4aPro
Best answer by MilkyWay
It should work on Koodo for now, but the main issue is whether or not your phone is compatible with VoLTE on the Koodo network. https://www.koodomobile.com/en/help/volte
If it does not work, you will be stuck on the 3G network when making calls, which will subject you to a price increase. Furthermore, the 3G network will be decommissioned on March 1, 2027. You will eventually end up having to get another phone. https://www.koodomobile.com/en/help/explaining-koodos-3g-usage-price-increase
According to this comment, the Nothing 4a Pro is not compatible on Public Mobile and is mainly relying on the 3G network. This would apply to Koodo as well.
I would not suggest you to get the device unless you are aware of the risks and still want to proceed with the purchase.
Login to the community
