disabling call forwarding
  • Jun 23, 2023 3:47 PM UTC
  • 1 reply
  • 330 views
Hi, I am having trouble disabling call forwarding option on my phone. I had this feature enabled for 50 days while travelling, and can’t disable it right now. Every attempt results in an error. I tried
#21#
##21#
*#21#
to no avail. The following show the error. I tried that on two different iPhones (mine an my wife’s) and they both fail deactivating forwarding, hope somebody can help.
1 reply
  • Jun 23, 2023 5:09 PM UTC
I assumed you were using an iPhone. You could go into the settings » phone » call forwarding » remove the forwarded number there.
