constant calls from unknown numbers............
  • Feb 23, 2022 8:28 PM UTC
  • 4 replies
  • 235 views
I rarely use my phone and do not use text etc…………………
As of now am receiving many calls today from
other side of the country. Do not know any of
these numbers………….what can I do to stop
these.  Am senior and not into tech stuff.
thanks for any help……….
Best answer by Sophia
Yikes, yeah prepaid doesn’t offer that feature, sorry about that :( Did you register your number on the do not call list? https://lnnte-dncl.gc.ca/en/Consumer/Register-your-number/#!/
That may help at least a little for calls originating from Canada...
Sophia
  • Feb 23, 2022 8:47 PM UTC
Are you on prepaid or postpaid? On postpaid you can enable call control. If they are robocalls they will be blocked because people will have to punch in a digit to get through to you. I enabled it on mine and it’s wonderful - no more spam calls!
  • Advocate
  • Feb 23, 2022 9:00 PM UTC
i AM ON PREPAID………………….SO MAY NOT BE ABLE TO USE CALL CONTROL.
THANKS FOR YOUR REPLY
Sophia
  • Feb 23, 2022 9:04 PM UTC
  • Advocate
  • Feb 24, 2022 4:33 AM UTC
Thanks again have now registered my number with the do not call list.
Appreciate your help!
