Cant get wifi calling to work
  • Apr 15, 2026 10:49 PM UTC
  • 11 replies
  • 92 views
Im trying to set up wifi calling on my phone. My phone number is not recognized by the koodo site when I enter it. My device appears to be VoLTE compatible.
Allan M
  • Apr 15, 2026 10:51 PM UTC
What device do you have?
Its a Galaxy S23 FE
  • Apr 15, 2026 10:57 PM UTC
Does VoLTE work?
When you are making a voicecall in a LTE area, does your signal drop back down to 3G or stays on LTE?
Im not sure how to tell what signal im using, I just made a call and all I can see is signal bars at the top. Other than the wifi symbol, mute etc. No lte, 4g or 3g. Signal is very poor here, which is why I want the wifi calling.
  • Apr 15, 2026 11:07 PM UTC
In self serve do you see the free VoLTE add on in your plans and add-ons section?
The phone was purchased from Koodo?
It looks like youre on to something. The phone is from another carrier, was transferred over using my previous phone number about 2 months ago.
No LTE listed in add ons or perks. The option is not available to add. Unless I somehow.missed it.
  • Apr 15, 2026 11:14 PM UTC
Let me flag a rep for you to add the VOLTE add-on
  • Apr 15, 2026 11:43 PM UTC
Hello ​@Danontwowheels  In order to cover everything, you can reset the network settings and try to set up wi-fi calling again.  The VoLTE feature is enabled by default with the majority of the rate plans. It is best to schedule a callback in order to continue the troubleshooting with our Tech Support team.
Thanks, I tried resetting mobile settings and restarting. Still getting "The number entered doesn't match our records. Please re-enter your number." How do I set up a callback?
  • Apr 16, 2026 12:04 AM UTC
​@Danontwowheels You can set it up with our Koodo Assist.
Hi ​@Danontwowheels, I was able to attach your *09 number profile to the account, you should be able to set up the Wi-Fi calling now. Please restart your phone and test again, let us know if it worked, thank you!
