Can't send or receive texts from android users
  • Nov 5, 2023 6:53 PM UTC
  • 26 replies
  • 864 views
I ordered a new Iphone from koodo, it came in the mail and I did the transfer to take all the information off my old Iphone to put on the new one (both were with Koodo).  Everything transferred over fine, however, now I can’t send or receive texts from Android users.
Best answer by TayMattJosh
I was able to get it fixed.  I went into the store and the girl said I had created an eSIM but was also using the card SIM and they were conflicting with each other.  She deleted the eSIM and everything is working great now.
Thank you to everyone for your help
  • Nov 5, 2023 7:22 PM UTC
Hi @TayMattJosh
Are the services working for data and calling?
Are you using the old sim card in the new phone or did you complete a swap from the old sim to the new sim as per the article here https://koo.do/InfoSIM ?
  • Rockstar
  • Nov 5, 2023 8:14 PM UTC
Hi,
I am using the new SIM card that came with the phone, Koodo sent me a new SIM to put in the new phone.
  • Nov 5, 2023 8:19 PM UTC
Got it!
Did you already perform the sim swap using the instructions in the link provided above (under Sim card replacement and Upgrades)?
  • Rockstar
  • Nov 5, 2023 8:29 PM UTC
I’m sorry, I can’t see the article, when I click on it, it doesn’t say anything about Sim Swaps, I’m trying to find it because I definitely didn’t do that part.  I will keep looking.  Thanks very much so far for all your help
  • Nov 5, 2023 8:39 PM UTC
I believe the full link is below, you could find the instructions to switch sim there (sim card replacement 101& upgrade)
https://www.koodomobile.com/en/help/koodo-sim-support
  • Rockstar
  • Nov 5, 2023 8:57 PM UTC
Thanks very much for directing to the SIM Swap, I had no idea I had to do that, I just thought I was to put the new one in and carry on.  So I did that, waited the 15 min, restarted my phone and it’s still not sending texts to my android friends
  • Nov 5, 2023 9:01 PM UTC
Could you go to Settings » Messages » check “Send as SMS”, and make sure it was ON?
As well, you can try to disable iMessage and re-enable it to see if that can help.
  • Rockstar
  • Nov 5, 2023 9:20 PM UTC
Yes Send as SMS is on, I diabled  IMessage and Re-enabled it.  I did notice  under MMS Messaging there are two primary numbers (both are the same number) just didn’t know if something was picking up from the wrong spot because of that
  • Nov 5, 2023 9:41 PM UTC
@TayMattJosh
We can see that the sim swap has been performed successfully. Are you able to make/ receive calls? Are just the text messages that won’t send?
We recommend also resetting the network settings (this would also reset the saved wifi and bluetooth connections on the new iPhone)
  • Rockstar
  • Nov 5, 2023 9:47 PM UTC
It’s just sending text messages, they are able to send them to me and I get them.
I clicked on the reset network, however, my phone isn’t listed to show me how to do it.  Are you able to give me instructions, I have an IPhone 15 Pro.
Thanks
  • Nov 5, 2023 10:09 PM UTC
Thanks
You could reset network settings of the phone by going to Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings.
You would have to reenter your wifi and bluetooth passwords after a network reset.
  • Rockstar
  • Nov 5, 2023 10:18 PM UTC
Okay I did that and tried again, still not working
  • Nov 5, 2023 10:22 PM UTC
Did you use your existing SIM card and insert it into your new iPhone? Is there any signal on the phone?
  • Rockstar
  • Nov 5, 2023 10:26 PM UTC
I did try using the original SIM before I went online and did the transfer.  When I did is said SOS and nothing would work.  Then I did the transfer and put the new SIM in. There is currently only two bars  and it says Koodo at the top of the screen.
  • Nov 5, 2023 10:27 PM UTC
That means the new SIM is working now. Have you tried updating your phone to the latest version?
  • Rockstar
  • Nov 5, 2023 10:29 PM UTC
It says its running Version iOS 17.0.3, is there a newer version, if so how do I update it, it’s not telling me there is one to do
  • Nov 5, 2023 10:47 PM UTC
The latest version is iOS 17.1. You can refer to this page to see if you can update it wirelessly on your phone. https://support.apple.com/en-us/HT204204
  • Rockstar
  • Nov 6, 2023 12:46 AM UTC
Okay I have done the update and restarted my phone.  It’s still not working
  • Nov 6, 2023 1:46 AM UTC
That was weird, as you already switched sim and received a text from Koodo to the old sim.
What type of sms from Android was it? What error did you see when you tried to send a sms to an Android phone?
  • Rockstar
  • Nov 6, 2023 1:59 AM UTC
I didn’t receive a text from Koodo
It says not delivered and message send  failure
  • Nov 6, 2023 2:54 AM UTC
How was the Koodo signal in your area? As well, have you checked the Canadian number to make sure it was entered correctly with the prefix +1?
  • Rockstar
  • Nov 6, 2023 4:03 PM UTC
The signal is normally good, however, since I switched the phone it has been one or two bars.
Yes it has a 1 at the start
I just tried calling an android user and the call also won’t go through.  I can call Iphone users.
  • Rockstar
  • Nov 6, 2023 7:41 PM UTC
Update, I can receive incoming calls and text but can’t send texts to android users or phone calls to anyone (including IPhones).  I can only IMessage
  • Nov 6, 2023 8:51 PM UTC
Were you using an Android device before? Did you turn off RCS? https://messages.google.com/disable-chat
  • Rockstar
  • Nov 6, 2023 9:22 PM UTC
No I went from an IPhone 12 with Koodo to an IPhone 15 Pro with Koodo
