Can't enable WiFi Calling on Moto G Power
  • Nov 1, 2021 10:46 PM UTC
  • 16 replies
  • 1660 views
I don’t seem to have the WiFi Calling option anywhere on my Koodo Moto G Power phone. Any idea on how to turn that on?
Best answer by rikkster
Since your Moto G Power was not purchased through Koodo, this could be another reason why you can’t enable Wi-Fi Calling. While Koodo sells this phone, they likely keep track of serial and IMEI numbers which helps tell the difference between the phones they’ve sold and non-Koodo phones.
Try dialing *#*#4636#*#* from your phones’ dial pad. If this code works, tap Phone Information and scroll down to near bottom of the page. If you see IMS registration, VoLTE and Wi-Fi Calling greyed out or not provisioned, you will have to contact Koodo for assistance.
  • Nov 1, 2021 10:59 PM UTC
  • Nov 2, 2021 12:09 AM UTC
Yes, but when I go to the phone settings option, there is no “Calls” and none of the setting menu options have Wifi Calling anywhere.
  • Nov 2, 2021 12:10 AM UTC
Note: I can find a screen that has Fixed Dialing Numbers, Call Forwarding and Additional Settings - the same as the screen in this tutorial, but Wifi Calling isn’t an option there.
  • Nov 2, 2021 1:01 AM UTC
Are you on the most recent firmware? What carrier version are you on to? Is it the latest? If you restart the phone, does it prompte for an update?
  • Nov 2, 2021 3:51 AM UTC
I am on latest version. No update required. I can't see how to determine what carrier version i am on.
Does Koodo need to turn on the wifi calling feature for me?
  • Nov 2, 2021 1:00 PM UTC
Are you a postpaid customer? Was your motoG power purchased from Koodo?
If you are a postpaid customer, you could contact Koodo and ask them to provide the provision for wifi calling at their end but i am not sure if that will enable the settings in the phone.
  • Nov 2, 2021 3:32 PM UTC
I am a monthly customer (not post paid). I did not purchase the MotoG from Koodo.
  • Nov 2, 2021 10:56 PM UTC
A monthly customer is post paid.
Maybe the question should be Are you prepaid?
  • Nov 2, 2021 11:11 PM UTC
If you are prepaid then wifi calling is only available for post-paid customers.
  • Nov 3, 2021 6:08 AM UTC
  • Nov 5, 2021 2:48 AM UTC
Do you have the VoLTE add-on enabled on your Self-Serve account? Without that, you will not be able to use the wifi calling feature.
If you cannot add it to your account, you will need to contact a Koodo rep by scheduling a callback through Koodo Assist or sending a message on Facebook Messenger or Twitter. https://Koo.do/Chat
I think rikkster hit it right on the head.  I dialed *#*#4636#*#* , tapped Phone Information and scrolled down to near bottom. I see that VoLTE and Wi-Fi Calling are greyed out and not provisioned.  You say that I have to contact Koodo for assistance….  but how do I do that? There is no support phone number anywhere?  How do I contact them?
  • Dec 21, 2021 4:08 AM UTC
You’ll need to schedule a callback using the Koodo's Digital Asistant : http://koodo.ca.ada.support/chat/?language=en Enter #socialtech in the chat dialogue box to get to the “schedule a callback” window quicker.
  • Dec 21, 2021 4:38 AM UTC
Just to make sure that these services will work, are you a postpaid or prepaid customer?
If you’re a prepaid customer, then Wi-Fi calling will not work.
I am postpaid.  I my house is in a valley and I do not get cellular service when at home. I absolutely need the wi-fi calling to make this viable.  I tried scheduling a callback Koodo's Digital Assistant, and scheduled one last night at 6:00, but got no call back.  Scheduled another at 8:00 pm but got no call back.  Scheduled another for 9:30 am this morning, but got no call back.  Scheduled another for  12 noon, got no call back.  Have one schedule for 6pm tonight, but I am not holding my breath.  Do they generally call back?  I was told that Koodo supports wi-fi calling.  So far its been two weeks without mobile service at my house, and I work from home, so you can imaging how happy I am.  Thanks for your help.
Allan M
  • Dec 22, 2021 1:17 AM UTC
Can you check to make sure Koodo's number isn't blocked in your phone?
Are you getting the text messages saying that your call should be arriving soon?
