I had previously put a phone into my shopping cart, but no longer want it. I see no way of emptying the shopping cart so that I am able to look at new phones. It won’t let me. Anyone know how to fix this?
Can’t empty shopping cart
Best answer by Flo Koodo
If you click the cart, do you see any “Clear order” option or something similar at the bottom, that you can use to remove the phone from the cart?
Login to the community
or
