Block the call from China
  • May 20, 2023 9:47 PM UTC
  • 191 views
I keep getting spam call from China with +86 country code phone number. However, the number keep changing so call control is not working. Is any way I can just block all call from China?
  • May 20, 2023 10:55 PM UTC
Besides "call control", Koodo doesn't provide any extra tools to block spam calls.
I thought call control should block every calls that didn't enter the validation code correctly? In your case, why didn't it work?
  • May 20, 2023 11:39 PM UTC
The spam call-in number keep changing. If you can let me know how to deal with it that will be great.
  • May 20, 2023 11:48 PM UTC
That wasn’t strange though. Spammer had a pool of number to call and “call control” should stop it. You mentioned it didn’t work? what happened?
As well, just to make sure we are talking about the same thing. Is the “call control” that you mentioned from Koodo? https://www.koodomobile.com/en/help/call-control
  • May 21, 2023 12:27 AM UTC
I am looking for the help here but not getting criticize. This is great and please forget about this post.
Sophia
  • May 21, 2023 12:44 AM UTC
You’re not being criticised - we’re genuinely puzzled why call control isn’t working for you. What normally happens is that the caller needs to punch in a random number to get through. Robot callers can’t deal with that (just yet). Are you sure call control is enabled in self serve?
