activating iphone after android to iphone switch
  • Dec 30, 2023 6:28 PM UTC
  • 485 views
I’m a Koodo customer but I can’t get my phone number to transfer to my new iphone 15 Plus from the android phone it’s replacing. Managed to transfer files and such but can’t set up the cell# during setup or with settings. Do I need to buy a an Esimcard  to do this or is there one already in the phone?  Lost in Halifax.
Best answer by Dinh
I’m a dumbass. Same size as an android (TCL 20 Pro)?
It should be, both devices are using nano sim.
  • Dec 30, 2023 6:44 PM UTC
I assumed you were using a physical sim in the android device?
If so, Have you tried to put the sim card from the android phone into your iPhone?
  • Dec 30, 2023 6:47 PM UTC
No, I thought the iphone just uses an e sim. I may have been wrong...
  • Dec 30, 2023 6:48 PM UTC
Canadian iPhone model should have a physical sim slot.
  • Dec 30, 2023 6:51 PM UTC
  • Dec 30, 2023 6:58 PM UTC
  • Dec 30, 2023 6:59 PM UTC
I really appreciate your help- thank you!
