*#61# doesn’t work
  • Apr 29, 2022 12:58 AM UTC
  • 4 replies
  • 804 views
I’m trying to change how long my phone rings before voicemail picks up. It’s far too short for this old gal to get to the phone.
*#61# doesn’t give me my voicemail number. The screens below come up instead. Can i use the number from my recent calls log?
Best answer by Allan M
This article should help you find out your voicemail access number:
Allan M
  • Apr 29, 2022 1:35 AM UTC
Timo Tuokkola
What do you mean it doesn't show your voicemail number? It's right there, where it says “voice call forwarding when unanswered forwards to: +16475804001”.
  • Apr 29, 2022 2:16 AM UTC
Timo, it isn’t showing the number the instructions say. It’s supposed to look like 5555804001*11*10. It confused me. I don’t process new information easily.
It would be helpful is the showed a screenshot, or said the number is found in the first entry on the page — for some of us who need things explained in detail.
  • Apr 29, 2022 2:17 AM UTC
Thank you, Alan.
