5G not working on a 5G plan
  • Nov 26, 2023 8:28 PM UTC
  • 3 replies
  • 253 views
John Zarubiak
I switched to a 5G plan from a 4G plan and traded 5 gigabytes away for this process. Now I am only receiving LTE at 48 megabytes per second. Very disappointing. Is this part of the way things are promised? One thing receive another. I reset my phone. Took out the SIM card. When I first reset my phone it did show 5G for about 3 seconds and then went back to LTE
  • Nov 27, 2023 3:49 AM UTC
Which cellular plan are you on?
How many bar of signal you had when testing? 5G is just a part of the network, it doesn’t cover every corner or was weaker than LTE. So your phone might just pick the stronger signal LTE instead.
I recommend you run speed test out door in a location where you know a cell tower is around.
John Zarubiak
I was within a couple hundred feet of the tower and drove all over town yesterday near the other tower. They have told me that there is not really good 5G here even though the map shows 5G through the whole town. Kind of disappointing that I switched for now
  • Nov 28, 2023 4:57 AM UTC
You could try to contact Koodo technical support to see if they can reset your plan. I think there was an issue with a recent 5G plan. They mentioned they are working on it to fix. Not sure if it will be an automatic fix or not.
