"Your current plan is not eligible with Tab Basic" -- I have a $45/m plan
  • Nov 25, 2022 10:15 PM UTC
  • 11 replies
  • 1128 views
I am looking to purchase a refurbished phone with Tab Basic on my current $45/m plan. It seems this plan is not considered Tab Basic, even though https://www.koodomobile.com/en/help/Keeping-or-changing-your-plan-when-you-upgrade-your-phone shows it should count for any plan $40/m or above.
It gives this error: “Your current plan is not eligible with Tab Basic. To proceed please change your Tab selection. Change Tab”
(Also, I am trying to get a call back, but the system is crashing and not allowing me to schedule call backs.)
  • Advisor
  • Nov 26, 2022 3:08 AM UTC
Possible to connect me with someone from Koodo or schedule a callback? Let me know. Thanks!
  • Nov 26, 2022 3:11 AM UTC
Which plan are you currently using?
  • Advisor
  • Nov 26, 2022 4:20 AM UTC
It is called $45 2GB Unltd min Plan SFD for short.
Here it is in detail:
  • $45.00 per month
  • Unlimited Canada-wide minutes
  • 2 GB of Shock-Free Data
And more detail:
  • Unlimited international messaging
  • Call Display
  • Voicemail
  • Call Waiting
  • Conference Calling and Unlimited Canada-wide Family Calling*
  • Additional data $13/100 MB
  • Unlimited international messaging (text & picture)*
  • Nov 26, 2022 4:52 AM UTC
There could be some glitch in their system or your plan was "grandfathered" as of now, there are many other better plan at $45 price point. I recommend you look into a new plan.
  • Advisor
  • Nov 27, 2022 3:40 PM UTC
Ok, thanks. I’ll get it figured out when I am able to schedule a call back. It’s been broken the past few days.
  • Advisor
  • Nov 27, 2022 3:48 PM UTC
I just double checked in Self Serve, I can only see plans from $50/m and above. I know there are plans that start at $35/m for example. Not sure why they are not showing up. There does not seem to be a way to see all the plans.
  • Advisor
  • Nov 27, 2022 3:54 PM UTC
I was able to get a call back booked this time for tomorrow!
  • Rockstar
  • Nov 27, 2022 3:56 PM UTC
I don’t believe they generally allow a tab on a $45 plan. It seems they technically require $60 plan minimum but seem to often allow tabs on $55 plans (and maybe $50 if it shows it for you).
there are promos on right now that if you get a new tab and update your plan, with credits it would be $45/month for 2 years (but then would go up if you don’t change it in 2 years)
  • Advisor
  • Nov 27, 2022 10:10 PM UTC
This page shows that Tab Basic should apply for $40/m plans or above: https://www.koodomobile.com/en/help/Keeping-or-changing-your-plan-when-you-upgrade-your-phone
Thanks for the heads up, I may have to do one of these new plans as I want to get a “new” (refurbished) phone too.
  • Advisor
  • Nov 27, 2022 10:24 PM UTC
Is there a way to add Tab Basic to my $45/m plan?
  • Nov 28, 2022 6:03 AM UTC
Since you are on a legacy plan, you may need to switch to an in-market plan to upgrade a device on Tab Basic.
