Updating billing address isn't working
  • Aug 11, 2023 1:13 AM UTC
  • 4 replies
  • 113 views
I’ve tried updating my billing address using self serve but it doesn’t seem to be saving. I can find the new address with Canada Post but saving it doesn’t seem to update my billing address. Any way to fix this without calling?
  • Aug 11, 2023 1:28 AM UTC
Try clearing your browser's cache and see if that fixes things
  • Aug 11, 2023 1:33 AM UTC
I tried that earlier but unfortunately it did not seem to help.
  • Aug 11, 2023 1:42 AM UTC
I’d suggest sending a PM to Koodo via FB Messenger or DM via Twitter/X as you’ll have to indicate the address you want. A rep will be able to assist with manually adjusting it .
  • Aug 11, 2023 1:44 AM UTC
Thanks, will give that a try.
