Unable to sign up into self-service for days
  • May 30, 2026
  • 11 replies
  • 120 views
I am a prepaid customer, bought SIM at at a store. I received a invitation link via SMS to create a self-service account. I left it for a week and then tried with different browsers and devices to sign up for days now but it always says, when using the invitation link or without that “my session has expired, please try again”. That cant be the case because passing the verification checks (Phone number, email) takes me roughly 2 mins max.
I need to create the account urgently or I will loose service.
  • May 30, 2026
@comfix
Just to double check, if you follow this link below, you are still getting the same error?
https://prepaidselfserve.koodomobile.com/en/koodo/create-account
  • May 30, 2026
I just tried it again and yes, it still happens.
  • May 30, 2026
Can you try it on a different device or use the incognito mode of the web browser to see if that can help?
  • May 30, 2026
Same problem, tried incognito on notebook as well on phone
  • May 30, 2026
Unfortunately, the reps in the Community have limited access to prepaid plans and are unable to assist further. You will need to schedule a callback through Koodo Assist to speak with a rep. https://widget.telus.tiia.ai/koodoprepaid/koodoprepaid.html
  • May 30, 2026
@comfix Are you currently in Canada? Are you using a VPN by any chance?
  • May 30, 2026
Tried the agent but cannot get it to have schedule a callback, maybe because I cannot login as there is no account.
  • May 30, 2026
Yes I am in Canada, BC currently. No I am not using a VPN.
  • May 30, 2026
You should still be able to request a call back with the virtual assist, even if you don’t have access to self serve.
If you click on this link https://www.koodomobile.com/kpre/login and select on the right side Create my self serve account, are you still getting the same error?
  • May 30, 2026
I cant get it to do that. It always asks for me to Sign In and when I type “callback” it just does the whole spiel of “do you have an account” again.
I just tried once more, still, same error message.
I checked and there is a store on my route. I will check in with them tomorrow. Hopefully they can help me.
  • May 31, 2026
I was able to schedule a callback without an account. You just need to be persistent and prompt them a few times.
