unable to log into self serve, waiting over 3 hours for “account to be setup”
  • August 23, 2026
  • 11 replies
  • 126 views
I transferred from Public Mobile but have been stuck for over 3 hours but whenever I try to login it says
“If you'd like to link an account
Please wait for your account to be set up.”
I want to be able to respond to the message that I should be getting from public mobile to transfer but I have not received any messages or emails!
Please help !
  • August 23, 2026
Hi ​@Hayden23
Just to double check, you didn’t receive any activation email to sign up for a Koodo self serve account?
How did you transfer from Public Mobile? Did you use the Fast Switch option?
  • August 23, 2026
Does it show that your number has been successfully ported over to Koodo? Are you still able to make calls and send text messages on Public Mobile? If it does not work, that means the transfer most likely went through.
With regards to your Self-Serve account, I would suggest you to wait for an email confirmation from Koodo. It should be noted that it will take a day or two, since you need to complete a credit check.
  • August 24, 2026
@Flo Koodo i was given an email saying I’m registered for self serve already but whenever I try to log in it just continues to say
Im still able to use all my public mobile services but i still would like to transfer for the plan I registered for with Koodo, if possible!
  • August 24, 2026
@MilkyWay  It does not show that I’m ported to Koodo yet, I’m still able to login to my public mobile account and access my info and data usage, etc. and I was sent an email that I have already been registered for self serve and I just can’t log in since it just says
every time.
and I haven’t received any other emails or messages from Public Mobile or Koodo
  • August 24, 2026
Are you still using your Public Mobile eSIM? Do you see a signal on your phone?
  • August 24, 2026
@MilkyWay Yes I am still using the public mobile e sim and I have signal
  • August 24, 2026
That means you have not ported over to Koodo. As mentioned earlier, it means Koodo is still doing your credit check. I would suggest you to wait until you receive an official email from Koodo with the eSIM instructions.
  • August 24, 2026
@MilkyWay okay, so how long does it usually take to receive the email for the next step? (E sim instructions)
  • August 24, 2026
You should receive it once they complete the credit check.
  • August 24, 2026
@MilkyWay okay, thanks for your help
  • August 24, 2026
Hi ​@Hayden23
We were unable to identify an account based on your community profile. If the services are stil active with Public Mobile, we recommend scheduling a call back with the virtual assist so a rep can check the status of account.
