Unable to log into self serve
  • Oct 5, 2026 2:12 AM UTC
  • 2 replies
  • 73 views
I cannot log into self serve suddenly. I changed my password but still cannot login. If my account is locked, how can I unlock my account?
Best answer by MilkyWay
Did you try the steps in the following link? https://www.koodomobile.com/en/help/problems-logging
  • Oct 5, 2026 2:57 AM UTC
  • Oct 5, 2026 3:24 AM UTC
Are you a prepaid or postpaid customer? If you're prepaid, self serve is a separate portal and the community reps here can't access prepaid accounts, you'd have to go through https://widget.telus.tiia.ai/koodoprepaid/koodoprepaid.html
As well, just to confirm, are you currently residing in Canada? Without VPN? And not using satellite internet? I ask since their security system might flag suspicious activity and not allow the password change to go through properly.
If that all checks out, I would recommend you clear the cache and saved passwords of your browser, then try again on a different device in incognito mode.
