Unable to add mobile plan to smart watch
  • Oct 28, 2026 3:45 AM UTC
  • 25 replies
  • 141 views
I have a Galaxy Watch Ultra 2025 that I am trying to add to my plan and it is failing.
In my case I’d already paired a Samsung Galaxy S24 Ultra running on the Koodo network with a Samsung Galaxy Ultra Watch 2025. Both the watch and phone had the latest software updates previously installed. A working pairing is really important.
i went into the Galaxy Wear app and I selected Mobile Plans  in the APP settings and Koodo was the network option already there to be selected.  I was prompted to login to my Self Serve account with my username and password. Under the field where I enter my password, there is a little CAPTCHA box that is stuck on Verifying if I am Human. It then states Please Try Again and wants me to refresh the page. It never goes beyond this and I am unable to login.
I have ensure that I am connected to 5G while doing all this. I’ve set my default browser to Chrome, in the event something wonky was going on with Samsung Browser. I’ve reset my mobile network setting and it will not go beyond this point.
I don’t plan on using my watch as the main point of contact but I hike and whatnot and would like the option to enable to use cellular on the watch. I know that Koodo/Telus uses the One Number Plan or something and I think the switch needs to be reset on the admin side? I am not looking to add a NEW LINE - I just want the option to be able to use my current number. Also I am not sure if it makes a difference but I currently use ESIM on my phone and have no issues there.
Thank you for any assistance you can provide!
  • Oct 28, 2026 3:49 AM UTC
Are you able to clear the default browser’s cache?
How long have you been stuck at the captcha?
  • Ambassador
  • Oct 28, 2026 3:51 AM UTC
​@Dennis I am aware it is a duplicate post. I’ve updated the original as I had it linked to the incorrect account.
This account is the one that is mirrored to my Self Service login. I would like assistance please if possible.
  • Oct 28, 2026 3:52 AM UTC
Sorry I have edited my post.
  • Ambassador
  • Oct 28, 2026 3:54 AM UTC
I have gone through and cleared the default browsers cache and changed my default browser as well thinking it didn’t like Chrome or Samsung Browser.
I am still stuck on the captcha. It is spinning on Verifying….We’re verifying your human.  It doesn’t go past this point.
  • Oct 28, 2026 5:32 AM UTC
When did you start registering for the one number plan?
  • Ambassador
  • Oct 28, 2026 5:38 AM UTC
I started this evening actually.  I thought I was making progress but then the app froze and it's been downhill from there.
I've uninstalled Galaxy Wear and reset my watch back to factory and then repaired it. It still got hung on the verifying.
  • Oct 28, 2026 2:38 PM UTC
Hi ​@kmacsouris
We are sorry to hear that you are having issues adding the Smartwatch plan to your line.
Just to double check, are is VoLTE enabled on your device?
https://www.koodomobile.com/en/help/smartwatch-faq
  • Ambassador
  • Oct 28, 2026 4:45 PM UTC
​@Flo Koodo My watch is the Canadian version of the Samsung Watch Ultra and it has that enabled.
I think that when I was initially running through the setup and my app crashed, that the ESIM session is locked on Koodo/Telus. This would explain why I can't get beyond the verifying stage on my phone.
I was setting up a Samsung Galaxy Watch Smartwatch plan, but the Wearable app crashed mid-provisioning. The system is stuck in a pending setup loop. Can you please cancel/release the pending eSIM profile on my account so I can re-add it?
  • Oct 28, 2026 4:58 PM UTC
Hi ​@kmacsouris
Thank you for sharing the details!
We have checked and there is no pending esim profile that we can see on our end.
Is the line ending in *08 that you want to associate the watch with?
  • Ambassador
  • Oct 28, 2026 5:02 PM UTC
​@Flo Koodo Yes it is.
  • Oct 28, 2026 5:05 PM UTC
Thanks for confirming!
What we can try from our end is to refresh the network for this line and see if that helps.
In case it doesn’t, you would need to speak with the tehnical support team for further troubleshooting.
If you can turn your phone off for 10 minutes, please let us know (let us know here once you turn it off)
  • Ambassador
  • Oct 28, 2026 5:13 PM UTC
I'm turning it off now! Thanks for your assistance in this!
  • Oct 28, 2026 5:20 PM UTC
Thank you!
If you can please try again after restarting your device and let us know if you are able to add the Smartwatch plan.
  • Ambassador
  • Oct 28, 2026 5:34 PM UTC
  • Ambassador
  • Oct 28, 2026 5:35 PM UTC
Both the phone and watch were restarted.
Please see the screenshot. This is where it is failing.
  • Oct 28, 2026 5:43 PM UTC
Thanks for the screenshot!
One last thing that we could try from our end is to reset your self serve profile and see if this would fix the issue (this would mean that you would receive a new registration link to sign up for self serve - your services / plans won’t be affected by this). Let us know if you would like us to proceed with the reset or if you prefer to schedule a call back with the technical support so they can look into it further.
  • Ambassador
  • Oct 28, 2026 5:46 PM UTC
Let's try resetting as it won't affect my profile to see what that does.
  • Ambassador
  • Oct 28, 2026 5:58 PM UTC
Ok I can see that my account no longer works. How long will it take the system to push out a registration link for me to try?
  • Oct 28, 2026 6:26 PM UTC
We see that you managed to create the profile, can you please let us know if you are able to log in and see all services listed?
  • Ambassador
  • Oct 28, 2026 6:33 PM UTC
I was able to login. My mobile services are there but my streaming service is not. Can that be ported over to the new profile?
Now as  far as setting up the watch to my phone, I’ve used the new profile to try and login and it is still stuck on the same screen as the snapshot above.
  • Ambassador
  • Oct 28, 2026 6:53 PM UTC
​@Flo Koodo I just went through and cleared out all caches for my default browser and the Galaxy Wear app. I’ve made certain that the Android System webview app for the Playstore is current. I’ve turned off wifi and enabled my 5G. I have disabled private DNS in my connection settings for the 5G. Restarted the phone and it is still stuck on verifying as per the screenshot above.
As noted above, I will need my streaming plan moved over from my old profile to this one and I guess I need to speak with someone from your team.
  • Oct 28, 2026 6:55 PM UTC
​@kmacsouris
We are sorry to hear the issue persists!
We have just sent you a PM to confirm some more details, please check your community inbox when you get the chance.
  • Ambassador
  • Nov 3, 2026 2:47 AM UTC
Good day, I am still encountering issues with adding the One Number plan to my account.
I have received emails from Telus regarding porting my number over to them but I don’t want to do that. The plan would be more than what I am paying a month now.
When contacting support via the phone, the agents don’t seem to be well versed in this option. I am having issues with understanding why this plan cannot be provisioned on the backend by an admin. I am also having issues understanding why I am being deferred to Telus regarding a plan that Koodo offers.
I would like further assistance please. ​@Flo Koodo is there anything else that can be done? I’ve completely wiped my phone and watch today and it hasn’t resolved anything.
  • Nov 3, 2026 4:00 AM UTC
Hi ​@kmacsouris, we’ve sent you a private message to confirm some details. Please check your community inbox when you get the chance, thank you!
  • Ambassador
  • Nov 3, 2026 8:33 PM UTC
​@Koodo I have send an update on the current message chain we have going on.
Help??
