unable to acces self serve drop down
  • Nov 4, 2026 3:44 PM UTC
  • 3 replies
  • 23 views
I have registered for self serve and can log on to see the overview page, however,  when i chose the menu where the self serve drop down menu should be, it's not there.  I would like to port my number so that I am not paying 2 bills. I have tried to schedule calls but the reception at work is terrible and they won't accept an ext. Number. I would like to get this resolved ASAP. I have the Kudoo eSIM and a physical SIM from my previous provider.
Any help is appreciated.
  • Nov 4, 2026 7:51 PM UTC
Is your service still active with your previous carrier? Have you tried following the steps in the link to port over to Koodo? https://www.koodomobile.com/en/help/moving-your-number-koodo
  • Nov 4, 2026 8:09 PM UTC
Does the Koodo line work currently?
  • Nov 4, 2026 10:29 PM UTC
​@Dennis Yes, i have tested it. I have the temp phone number number and  I can switch between SIMs and it shows the network provider at the top of the phone.
​@MilkyWay I can't access anything under self serve to chose the option to port over. It just says not available at this time.
