travel pass question
  • May 6, 2026
  • 11 replies
  • 100 views
I have added the 14 day travel pass. Koodo says it is active as of May 5 and expires June 5.I will not be using it until May 29th. Will it not be active for 14 days from then? If not, how do I cancel?
Best answer by Dennis
It will expire June 5.
I recommend adding it a couple of days prior to departure.
If you login to your koodo self serve go your plans and add-ons and you can remove the travel pass add-on
  • May 6, 2026
  • Organizer
  • May 6, 2026
No link where I can remove my pass. Should I not add it until I am at my destination?
  • May 6, 2026
You can choose to add it once you arrive at your destination country, but it is best advised to do it earlier before you leave Canada to avoid any interruption to your services. Let me flag a rep to remove it for you.
  • Organizer
  • May 6, 2026
So you are saying that I should add it as I am at the airport waiting to take off for Europe?
  • May 6, 2026
No. Add it a 2 or 3 days prior to flying out would be fine.
When you check your add-ons on self serve do you see the travel pass added on there?
Hi ​@Dogtor, would you like me to remove the Travel Pass from your *88 line? You can use the 14-day pass within the 30 days following it being added to your line.
  • Organizer
  • May 6, 2026
Yes please.
  • Organizer
  • May 6, 2026
Travel pass shows up in my add ons but $0 beside it.
Ok ​@Dogtor, I’ve removed the Travel Pass from your *88 line. When you’re ready to re-add it you can do so via SMS from the line in question.
It will show $0 as the pass is only charged when you first use it while roaming.
  • Organizer
  • May 6, 2026
Thanks. Where do I send it on SMS?
  • May 6, 2026
You can text EU14PASS to 7626 for the 14-day Easy Roam Travel Pass when you are ready to add it to your account. https://www.koodomobile.com/en/help/europe-easy-roam-travel-passes
