Text usage not showing
  • May 26, 2025 6:10 PM UTC
  • 9 replies
  • 365 views
I have two phones on my plan. When checking usage only one phone is showing text activity even though it has been used. Not using messenger. Can this be turned off or why would this happen?
Best answer by Dinh
Just regular text, this phone doesn’t have facebook or any other texting apps.
I assume you are using an iPhone? I am not asking about facebook or other texting app though.
iMessage and RCS is currently incorporated in the normal messaging app of the phone and using the default messaging app? what is the color of the text in the messing app?. https://support.apple.com/en-ca/104972
  • May 26, 2025 6:31 PM UTC
Hi ​@Houli
Just to double check, are you checking the usage in self serve or on your phones?
  • Advisor
  • May 26, 2025 6:40 PM UTC
self serve
  • May 26, 2025 6:52 PM UTC
Thank you!
We do see there are a few message on one line and one on the other line, for the current billing cycle.
If there are more messages on your phone, they might be counted as RCS/iMessages, which use mobile data or wifi to send: https://www.koodomobile.com/en/help/rcs-messaging
  • Advisor
  • May 26, 2025 7:02 PM UTC
No these are just regular text messages on both phones. I guess I’ll just wait and see for a while.  Thank you!
  • May 26, 2025 7:09 PM UTC
Do you notice anything unique for the messages that do show up in your usage?
  • Advisor
  • May 26, 2025 7:15 PM UTC
No the only message that shows on the one phone was the activation message.
  • May 27, 2025 2:18 AM UTC
Which device are you using? are you using RCS or iMessage by any chance?
  • Advisor
  • May 27, 2025 9:48 PM UTC
  • May 28, 2025 12:00 AM UTC
