SIM to ESIM Issue
  • June 9, 2026
  • 7 replies
  • 410 views
Bought a new  phone for my son. We attempted to transfer to an iPhone 16  from his  old phone with a physical SIM. During the move, the conversion from physical SIM to eSIM failed. It did however deactivate my physical SIM so now I have no service. on either phone. Can someone assist? Thank you
  • June 9, 2026
What happens when you insert the physical SIM card into the phone?
Have you tried to recover the eSIM from your Self-Serve account? Did you restart your phone after the swap? https://www.koodomobile.com/en/help/esim-and-esim-vouchers
  • June 9, 2026
The physical SIM into the new phone? The new phone doesn’t have a physical tray.
  • June 9, 2026
Does the physical sim work in the old phone or another phone?
Did you try the esim recovery in self serve that Milkyway suggested?
  • June 9, 2026
@Son-1138
Please try the steps provided by ​@MilkyWay above and also try resetting the network settings on your phone.
Let us know if that helps.
  • June 9, 2026
Thanks for the replies. Unfortunately I need to work but I’ll attempt these suggestions and il respond when I’m able.
FYI: we did try to restart the phone multiple times.
We attempted the SIM to eSIM Transfer using Apple’s transfer “tool.”
  • June 9, 2026
You tried, but did it work?
  • June 10, 2026
If your eSIM didn’t work, it might be deleted or the process didn’t complete successfully. You could try to go to Selfserve » Mobile Services » Select your number » Get helps with eSIM and SIM cards » Select the option to recover eSIM
If that doesn’t work, you might have to visit a Koodo location and ask a rep to transfer your number into an eSIM voucher and scan it there.
