seasonal hold
  • April 22, 2026
  • 66 views
I can’t seem to set up seasonal hold for my account, it keeps loading and never lets me fully set it up, any idea what could be the problem?
Allan M
  • April 22, 2026
Are you able to try using a different device and/or browser and see if self serve loads properly for you then?
As well you could try an incognito/private window.
  • April 23, 2026
Did you manage to get this setup ​@Maelo? If Allan’s suggestions did not work, we can flag a rep on here to assist.
  • April 24, 2026
I’ve tried different devices and different browsers as well as incognito mode, nothing seems to work
  • April 24, 2026
ok, in that case I will flag a rep to assist. Make sure you’re logged into the community using your self serve credentials and they should be able to help. 🙂
  • April 24, 2026
Hi ​@Maelo, we’ve sent you a private message to confirm some details. Please check your community inbox when you get the chance, thank you!
