Register for Self Serve without the ability to get text Message
  • May 21, 2026
  • 3 replies
  • 54 views
I’m trying to register for Koodo Self Serve using my phone number, however it gets stuck on text Message. Currently, I’m not able to receive the text message as I’m using the sim card inside Mifi. Is there any work-around to register ?
Best answer by MilkyWay
You will need to insert the SIM card into your phone to receive the text message. Once that is complete, you should be able to plug it back into your router.
  • May 21, 2026
Are you registering for a prepaid or postpaid plan? Did you receive a registration email from Koodo? Assuming you are porting over, have you tried taking out your SIM card and putting it back into your phone? https://www.koodomobile.com/en/help/registering-self-serve
  • May 21, 2026
Prepaid plan and activated it in Koodo store and received the registration email. But currently I’m using Koodo sim only for internet and have installed it into Mifi Router which doesn’t have ability to display text messages. So was wondering if there’s any workaround to register without having the sim being installed into my Telus sim phone?
  • May 21, 2026
