Question about the Self Serve Messaging details
  • Dec 25, 2022 11:51 AM UTC
  • 3 replies
  • 579 views
Can anyone tell me when checking your usage details in regards to messaging why some messages do not show up in your details ?  Had a back and forth conversation via text and the persons number didn’t show up in my history?
  • Dec 25, 2022 4:58 PM UTC
Which phone are you using? And which type of message were used?
Koodo message usage only showed SMS/MMS. If you were using different type of message like RCS or imessage, the system couldn't show it because those are not Koodo service.
It's I message so I guess that explains it.  But it will show phone calls in the minutes usage
  • Dec 25, 2022 5:13 PM UTC
Yes, it can show because Koodo service provided  normal calling. If you used Facetime audio, then it couldn't report.
