Port notification text never came?
  • May 31, 2023 1:42 PM UTC
  • 1 reply
  • 90 views
Port notification from previous provider never arrived. Should I just switch Sims now and hope it will work without the YES? seen others replies that they never got the text but the number ported anyways
1 reply
  • May 31, 2023 5:38 PM UTC
Who were you porting from?
You can always put in your koodo sim to to see if the new number is active.  There is no disadvantage to that
